Hunterut45
Thread starter- Joined
- Jul 11, 2017
- 10
Hello everyone I am new to the forum. I am contemplating on renovating a 1992 Rinker Captiva 186.. I have owned this boat since 2002 and has been a great boat. The motor died last year and the boat has sat since then. Also last year I noticed that the floor felt spongy where it ended at the engine compartment. As well as the top of the storage compartment on the port side. The vinal had started to were after 28 years (became brittle and started to crack in places). The wife and I started looking at newer used boat and felt spending anywhere from 35K to 70K was not what we wanted to spend. This brings me to the major renovation of the Rinker. Thoughts at this point is to see what the damage is and come up with an estimate for what it would cost to restore this boat.
At this point in time I have removed engine, transom and all other items except for the upper half of the hull. I have attached some pictures for the two questions I have at this time. 1st to the left an right of the transom where the out drive mounts is there plywood in the transom below the flooring on this boat. (from tapping on the outside of the transom it sounds line it is all composite material). 2nd I removed the screws to sperate the upper and lower hull parts and the upper dropped about an inch. Will this cause an issue I do not have the supports in place (cradled)
