1992 Stratos 2250 here we go again
ahmincha
Well the 2 feet turned into 6 feet but I'll know its done. my guess is it was probably there from the 3 impact holes I repaired when I did the hull but it didn't come thur the hull and was covered by bottom paint.
My new plan is to use poly resin being its this big and hanging epoxy would stink.
So I am going to smooth it ourt a little with hairy pb then csm 10 oz csm 10 oz csm fair and paint
And the culprit
nurseman
Sounds like a solid plan. And probably a good thing to just have it done right.
ahmincha
I'm sure it would of been fine but I figured once motor is on im not sure it will fit on my lift and if it did fail thats alot of extra work just because I got lazy. Plus I did miss grinding fiberglass LOL.
Well here is a hairypb with 1 layer csm and 1 layer 10 oz all done wet on wet. I hate going over pb after it hardens
Woodonglass
Nothing like Peace of Mind when your in the middle of the lake!!! Now you have it!!!! Nice Job!!!!:peace:
kcassells
Good stuff Mr. Minch! Dat's all I have to say about it. Check around though for other little nightmares since your at it.
Nice yob!
ahmincha
Yeah I've looked around there is some cracks in the gel coat above the waterline. But I believe the superficial. I'll post some pics tomorrow for reassurance.
ahmincha
these are on the bow mostly on port side above waterline I'm assuming there superficial Chine up more at chine cracks are bottom rt
Woodonglass
Minch, ondarvr has forgot more about Gelcoat than I'll ever know. I'll ask him to drop in and have a look.;)
sphelps
I agree ... might want to get a pro to give it a look see ... May just be a drimmel and fill or you may need to do a bit more to keep it from returning ..
Lets see what ondarvr has to say ..
ahmincha
If its cosmetic I'm not worried about it. I went looking at old pictures and can't tell if they were there before rebuild.
ondarvr
They won't be easy to fix, and it looks like that hull had a rough life. There are so many cracks that grinding out each one individually would take a long time, plus because it looks like there is, or has been, a great deal of flex in the hull, they could come back soon. Sometimes you just need to sand down the worst areas, add some glass, then fair the surface again.
ahmincha
Thanks ondarvr, This was a police boat so I am sure it had a rough life. Cosmetically I couldn't care less about these. I am more concerned that they are structural which I do not remember any cracks on the inside of the hull when I redid it. I know this is a loaded question nad your many miles away but do they look structural or something I should fix opposed to being cosmetic? thanks
kcassells
Find the worst of them, repair and paint...you are on a roll. What a great bunch of guys and info. That boats gonna get wet again real soon.
ahmincha
problem with that kc is they are above the water line I am not painting the exterior hull I was just concerned they were structural but my best guess is it seems like this boat was beached a lot and I'm thinking while being beached the front would flex while the rear was floating. May be far fetched but that's my story and I am sticking to it
Actually I can see into most of the areas where the cracks are and I think its only in the gel
ahmincha
Also does it take longer for fairing to set up poly? It seems like it does not want to set it eventually does but seems longer then regular layups
ahmincha
well body man I am not . was wondering will the crookedness of my work have any ill effects
kcassells
On a serious note Minch, the crookedness attracts more fish. BTW, not that I see any, anyhow! Good to go man. Put a worm on da hook.
