1993 9.9 hp johnson throttle handle
bunky28
how can the handle be adjusted so as to put a little more tension on it? the handle seems to be a little to free. i cannot set the speed for trolling as it keeps moving when i take my hand off of it.any suggestions would be greatly appreciated
Haffiman
Re: 1993 9.9 hp johnson throttle handle
A hose clamp around the rear part of the twist handle may solve that problem. You may buy the original clamp, or just go 'cheap'.
bunky28
Do you know where i can get the original clamp?
the machinist
Go back to the FAQ on this section. On the top of the 2nd page you will find a link to 9.9 / 15hp OMC motors. There is a link to the 93 plus motors there. In it I describe how to use a electrical split ground clamp on the throttle cable that works great.
