I have a 1993 Mariner 25hp outboard and the tach works for a minute or so when i start the boat then dies. I have checked the rectifier with the leads disconnected and it tests good. The tach works fine in another application so I know its not the instrument. Has anyone ever run across a rectifier that tests good without power and when applied power will fail? I am trying to get a handle on this and can't. It appears the battery is not charging also. The stator tests good with a multimeter so I know its not that.Would a bad battery cause this? If anyone has any ideas I would be grateful.
