saltybutwet
Thread starter- Joined
- Jun 30, 2013
- 197
Re: 1993 Mercruiser 3.0 new to me, with major problems, Not Running, Water mixed with
thanks for the info
With air you'll have to figure out a way to seal off where the riser bolts to the manifold, can be done, but not easy. With acetone, just fill'er up and watch for leaks. Acetone isn't that expensive, $15-20 for a gallon isn't too bad in the grand scheme of getting the engine running again. With that amount of water in the oil (looks pretty diluted to me) it may not be the manifold, but I'd rather verify if is/isn't the manifold. If not the manifold, you're looking at the head or block :faint2:
Re-torquing the head is suggested after the first head/cool cycle, and maybe that would seal up a leaky head gasket, worth a try I guess....
thanks for the info
