1994 40hp Johnson run
Force 120
Please listen to the weird sound intermittently spark firing. Is it normal or not?
airshot
Looks quite smokey, fuel/oil ratio correct, if rich a temporary plug foul ???
Force 120
Yes I hear it. A wire is sparking somewhere. Start it after dark. Probably why it's missing.
Yes, I never think about let it run after dark to see where the spark coming. It is very dangerous if the leaking gas and open spark somewhere on the motor.
tphoyt
If you have leaking gas why not fix that problem first. Of course you will still need to run it to see if it’s fixed but if you have plenty of fresh air flow and your in a confined closed up space you should ok.
Famous last words.
