petermarcus
- Joined
- Apr 30, 2010
- 132
Re: 1994 Bayliner Capri 1950 Restoration
Man I'm tired of the demo work. I want it to be over with, so I can start to get tired of the grinding work.
It's been slow, because it's Florida. It's either raining horizontally, or it's 94 degrees with 94% humidity. On the weekends, I've been grabbing an hour or so in the morning before it gets hot, and the rest of the week, I've picked an hour right at sundown until it gets dark.
But! Got just about every bit of wood out of the boat at this point. Stringers gone, bulkheads gone, tank supports were rotted out, they're gone. Battery shelf, it's all gone.
Demo chaos, but one stringer gone. I pulled up the glass over the port tank support, and it's rotted to pieces:
Here are the stringers. They look burned, but that's rot. They weren't plywood either, but fir or something similar. I know it's a joke running around, but they really did look like old broken up pallet wood. They also didn't seem to be one long stringer, but one piece from transom to tank, then up against a bulkhead, then another alongside the tank to the next bulkhead, then another piece to the front of the boat. Three pieces, butted against bulkheads in between:
The motor mount seemed to be one chunk of wood carved to fit in the bilge. Maybe a 4x4?
Making progress:
Getting there:
Facing aft. The right side glass on one of the mounting plywood panels pulled up, and that plywood is gone, too, so I have more transom work to do.
I have to pull off that mounting plywood (it's just poly hull underneath, it's isolated from the rest of the transom). I have to tear off the rest of the shelf around the outdrive part of the transom. And that's it. There remains one bit of isolated plywood on the stern where the dive ladder mounts, and it'll probably be the only bit of original wood left on the boat (I've taken several samples, and oddly, it's all good). I've considered replacing it anyway, but it's in an easy to get to area, isolated from the rest of the boat's structure, so I'm leaving it for now for historical value.
It's a very odd thing, this shell of a boat. My trailer has bunkers supporting virtually the whole length of the boat, but there's this flex now. Without the engine, the outdrive, the deck, the stringers, the bulkheads.... I can go to the corner of the stern and actually lift my 19 foot boat off one of the bunkers.
Making progress:
Getting there:
