petermarcus
- Joined
- Apr 30, 2010
- 132
Re: 1994 Bayliner Capri 1950 Restoration
It was annoying, but not bad. The rot had creeped up the back of the good plywood, so chunks of the good stuff came off easier than I thought. I also went over the good wood with a circular saw in a criss-cross pattern, which made it easier to pry up with a pry bar -- it all came apart in chunks.
Here it is with most of the wood gone, just a couple ply thicknesses in the top right, and some skin over the rest.
MountaineerMiner was right about the flap disk on the grinder. Took the plywood skin clean off the glass hull.
Always wear your safety gear!
While the respirator and goggles are essential, I can't handle the paint suit in Florida in July. It's either itch a lot without it, or sweat out a river and maybe get heat stroke. I'm basically working in my driveway, so I've been doing demo work in the morning when the house shades the boat. Frequent breaks to gulp water and soda.
I'm pleased about the transom, though. I have a little bit more to clean out at the bottom, but I moved on to other areas.
So, the stringers were glassed up next to the transom, but the ends weren't capped, it was just wood to wood. Guess what? Ends of the stringers are gone, of course.
The battery box sounded hollow, and it was.
I'm tired of waterlogged foam. I've been going back and forth about whether to add foam to the boat when I re-deck, and if you ask me right this instant, I don't want to see the stuff again.
But, give me a while. I'd like to maybe come up with some sort of foam system under the cap. Noodles or torn up PFAs or something. I don't think I can stuff enough under there to balance the weight of the boat, though. I'll think about it more after I finish the demo and don't have my hands full of wet foam any more.
