- Joined
- Oct 25, 2011
- 25,251
Re: 1994 Chaparral 230 rebuild thread
You'll be using quite a bit of 1.5oz CSM to make up for no 17oz biaxial 1708. And in terms of design strength, it will be resin rich & fiber weak. The biaxial cloth (1708) should be stronger then multiple layers of Chopped Strand Mat.
This is the best practice, to answer your question, as suggested widely across most of the iboats resto forum:
"Fabricating Decks, Stringers, and Transoms"
I'm not sure I understand your last 2 posts:
In 1 you ask 'can I skip the 1708 I've read that many have recommended'?
Then in the next you ask for the best, strongest, better then factory way to rebuild the boat and the best way to seal wood.
