Re: 1994 Chaparral 230 rebuild thread
Maybe what im pulling up is not tabbing... I could be calling it something wrong. Whatever it is its the stuff that was used to hold the stringers to the hull.
It looks that they installed the bulkheads and stringers then used maybe a chopper gun to spray everything down with glass.. Maybe ????? Or installed the bulkheads and stringers and used CSM to hold it to the hull.
Im pretty sure no biax was used to hold the stringers down. The stuff im pulling up is between the stringers and seems to run up the sides of the stringers. When I pull up what remains after the stringers are gone I get down to what appears to be something like biax cloth that was used to build the main hull.
Even in the rear bilge area it appears they used something similar to buildup around the motor mounts. The floor section is very thick and I almost wanna say was applied by a chopper gun.
Ill see if I can get some pics at some point so you can see.
We do need to see some pictures of what you are doing . . .
I have been repairing the structure of my Formula and I can say what you are seeing in your boat is not typical of other boats. The tabbing on my boat is a fairly thick biaxial cloth thoroughly wetted.
