imported_JohnN
- Joined
- Feb 19, 2007
- 11
I have a 90 hp Johnson on a 16 ft boat I recently purchased and I noticed one of the float chambers was cracked leaking gas after my first run with it. I changed both the chambers on the carbs and now it runs hideously bad. Can anyone offer any insight as to why it might be doing this now? Model # J90TLERC Any help would be appreciated. Incase you need to I removed the breather covering then removed the carbs replaced the float chambers, gaskets and the gaskets between the carbs and the block. Reassembling was just the reverse. Thank You
Forgot to add something: When I throttle up on it there is no power gain at all. It just sputters and smokes ALOT!!!
