1995 200 hp oceanrunner carb adj
toghog
Happy 4th to all, I have a 200 hp oceanrunner 1995 it is a eo series. I have the plastic carbs.A friend told me I possibly had a carb running lean and I needed to richen it up.This is to correct a low speed shift stall out problem.The motor stalls at the dock when shifting,also it sneezes while in reverse other wise it runs perfect. I have gone over the linkage,and all moves nice and free. any advice ? thank you tog
tashasdaddy
Re: 1995 200 hp oceanrunner carb adj
your motor has fixed jets, if it's running lean it's because a jet is partially clogged. not letting enough gas thru to mix with the air. cleaning and rebuild time. what is your idle rpms in gear. they may be too low.
Walker
That motor may have adjustable idle jets. Look at the air box and see if there is a small hole in front of each carb.
toghog
the idle in gear is 750 thanks
toghog
no holes in air silencer. What does that mean ? thanks
tashasdaddy
set up your rpms, or clean your carbs. preferable clean the carbs. especially if they have never been done.
toghog
Thank you, I bouhgt boat at the end of last yrs season and have no idea if carbs were ever done, I will clean the carbs and see how it goes. I had a feeling they were non adj. I am still on heavily treated tank of gas istill have not burned up last yrs tank) could all the additives be the problem. I added all the additives that omc say's to for a store up. It was in storage for 3 months. tnx again
hoeser
3 month old gas isn't bad at all... Even if the additives are partial cause of this problem clean the carbs anyway, a lean carb can cause major problems.
tashasdaddy
burn up most of that gas before refilling. and no need to store gas. i have a 50 gallon tank, that has never had more than $40.00 worth put in it.
