1995 40hp oil injection buzzer
M
Maxz695
Guest
Re: 1995 40hp oil injection buzzer
anytime let me know how it comes out. please remember this is adding a small amount of oil 50 to 1 of gas. I wouldn,t think it,s gonna come gushing out
armentroutkt
I found one on ebay that is exactly the one I have. I wonder if that phillips screw is the bleeder?
M
Maxz695
Guest
I have an oil injection pump for 40 hp 4 cycle 4 cyl 1997 out back let me check it out i,ll get back to you
M
Maxz695
Guest
Expensive wow at that price maybe i,ll clean the one i have out and list it, It has gunk in the pump lines. the engine i stripped was a 1997 40 ho oil injected 4 stoke 4 cylinder I still have the stator flywheel 3 coils fuel regulator stator adapter and a main electrical part wit alot of wires going through it. if you need. any of them before they sell on eBay let me know I,ll make an offer you can,t refuse. did you disconnect the hose from the engine at the pump. leaving the line from the tank? turn engine until it pumps good then replace the engin hose. That may be the bleeder hole but undoing the hose is a good idea. Update after inspection of the pump which appears to be the same as yours it is easy to take apart clean inspect and rebuild. The screw you indicated does seem to be the bleed screw at the bottom of the cylinder I sent you notification you may want to read. The pump i have appears now to be sucking when i vaccum it through my mouth (Draws) I,m gonna try with oil in a bit. spining the driver. I Used carb cleaner to shoot out the lines passagways and the pump cylinder. then reassemble it
M
Maxz695
Guest
expensive wow at that price maybe i,ll clean the one i have out and list it, has gunk in the pump lines. the engine i stripped was a 1997 40 ho oil injected 4 stoke 4 cylinder I still have the stator flywheel 3 coils fuel regulator stator adapter and a mail electrical part wit alot of wires goint through the. if you need. any of them before they sell on eBay let me know I,ll make an offer you can,t refuse. did you disconnect the hose from the engine at the pump. leaving the line from the tank? turn engine until it pumps good then replace the engin hose. That may be the bleeder hole but undoing the hose is a good idea
after taking apart the pump and cleaning it out with carb cleaner everything is ok. There is a sklight wear in the wall of the pump cylender exposing light signs of wear. The screw you spoke of does in fact appear to be the bleeder at the bottom of the pump cylinder. this is not hard to do a cleaning on th be sure no clogs in or out exist. I,ll post pics View attachment 90647View attachment 90646View attachment 90648View attachment 90649View attachment 90650 NEW UPDATE I took a seashell Clean and dropped 2 cycle oil in it. kept filling the hose with the bleeder out and spinning the drive with my cordless 9v drill attached to the drive took some time to completely fill the pump.replaced the bleed screw and tryed again with a result of a very slow steady stream of oil coming ot of it indicating it is good. maybe you should replicate this action and test the pump after cleaning it if not you have the notification. message me before acting on any of the links thats ebay price not yours
armentroutkt
Hey Max,
Took the boat out Saturday all day and ran the livin daylights out of her! That little boat flies! I tried trimmin her out at about 37mph and it would start bouncing. Need some trim tabs LOL!
That pump looks immaculate. Good cleaning job! That pump looks new. I've got the fishing fever now! Went to my favorite crappie hole in the Rappahannock River. Of course it felt like the wind was blowing 40+. I wish I could get one calm day. Caught one crappie and one giant bass on minnows.
That was a good idea with the drill! That pump looks identical to mine. Is it the same one?
M
Maxz695
Guest
great to hear I,m really happy that the information did help get you out there and fishing . Me i,m stuck. I only recieved half my parts yesterday and the thrust washer for my new prop set up was the wrong one. Anyway.I,ll be around give me a shoult let me know if theres anything eles I can help with. Have great day scincerely George B
