armentroutkt
Thread starter- Joined
- Apr 15, 2008
- 58
I want to apologize in advance if I'm kicking a dead horse on this subject. I have read an overwhelming amount of information on this forum and am having a hard time deciphering what tests I should try first. Sorry for my ignorance.
1995 Mercury tracker 40hp
When I turn the key, yep you guessed it..beep beep beep beep non stop. Not a continuous beeeeeeep.
I opened up the electric box to see if anything looked out of whack. Sure enough the voltage regulator looked like someone tossed some thermite on it!! LOL. I replaced that hoping that might have something to do with the oil sensor. NOT!
So I moved on to the tank. I read somewhere in here to flip the tank upside down to see if it would stop... no luck. I tried something a little different. I took the sensor out of the tank, filled up a cup with oil and put the sensor in the cup. NO BUZZER, just the initial beep when the key is turned on. I put the sensor back in the tank and filled. BEEP BEEP BEEP continuous. Does this mean the tank is bad? Or the float inside he tank??? Any suggestions?
Thanks again!
Thanks again!
