1995 E200TXE0 200HP dirty carbs ?
Jimdsi
After speaking with several people who should know, the reason my engine runs like crap at low speed is probably dirty or clogged jets in one or more of my carbs. How difficult is it to remove a carb and check the jets? What, exactly would I be looking for? The engine misses and runs rough at idle speed or slightly above. At mid speed or better, it seems to run fine. My local yard is willing to do the work, but they can't get to me for 3 weeks or so.
tashasdaddy
Re: 1995 E200TXE0 200HP dirty carbs ?
lets' try something else first. lets check spark and compression. if it is not running on all cylinders it will do that. but at higher rpms, can be hard to tell. go to the auto part store and buy a spark tester. connect the tester between the spark plug wire, and the spark plug. then have some turn the motor over, and you watch for spark in the tester. do all the plugs. if one is not firing, you may have a coil bad. report back.
