foleyba4
Thread starter- Joined
- Jul 7, 2014
- 9
I share ownership on a 1995 pontoon boat with a 60hp mercury, 3cyl, 2cycle outboard. Sometime ago the flywheel cover ended up missing so no one has been able to properly time the engine. I bought a flywheel cover (hopefully it is the right one). The motor seems to run well enough in idle. In forward speed it has very little power (can't really create a wake). In looking at the linkage it seems that the throttle lever is not going far enough backward for any of the throttle stops to make contact so I am thinking that maybe the throttle linkage in not properly set to allow the throttle to get the engine to open up to top speed. Does anyone have a similar engine that can take photos of the linkages at full throttle so I can compare to my engine. We have had the motor worked on by several different shops and no one has even questioned us as to why the cover is missing.............
