matt167
- Joined
- Sep 27, 2012
- 4,443
be sure to get a marine carb. 650cfm would be fineAnother quick question, what size of carb will be needed? Would a 650 cfm be big enough? Then mess around with the jetting to fine tune it ?
early V8 explorers as well. P's are for more common as I think the switch was in 1997True GT40 heads only came on 93 mustang cobras, and 93-95 ford lightnings from the factory and had 3 vertical bars on front of heads. Gt40p's have angled sparkplugs and came on explorers and are 61cc as opposed to 65cc which bumps stock compression ratio.
You are correct.early V8 explorers as well. P's are for more common as I think the switch was in 1997
