Re: 1996 150 Johnson Ocean Runner RPMs
Okay new problem... The results of the compression test and spark test are as followed. Spark was test with gap at 7/16 gap
Right Side Left Side
110, good spark 110, NO Spark
110, good spark 120, Weak Spark
So the new problem is the left side is not getting any spark at all. I checked the Shift switch and it seams to be working fine. The RPM are lower when it is pressed. I did a light test on the wire from the right side and there is steady power going to the right side of coils. But on the left side there is no power from the wires going to the Coils. The Power pack was put in last year Manufactured in 2008. I checked the connections in all the wire but they seam to be all connected well. does anyone have a wire diagram they could post or send me in email
dink1977@suddenlink.net for the coil and all the wires? Not sure what to check now. Please PLEASE HELP......
