I have replaced the following and it will only run or start with the choke out 3/4 and it runs poorly even then and often dies. This is a kicker motor and runs on the same gas supply through a filter seperator and the big motor runs great. With much help from you guys.<br />Compression is 90 89<br />I pulled the exhaust cover and the ring and pistons look great.<br />New carb kit and cleaned three times <br />New fuel pump kit checked flow at output ok<br />New hoses and hose fittings<br />Did link and sync<br />I installed a new head gasket<br />I installed a new thermostat<br />New spark plugs NGK BP5HS which is what it came with when it was new.<br />Pumping the primer bulb does not help<br /><br />I have the factory manual but no ideas.<br />I am down to the wire on this as I am leaving on a fishing trip in a week and have to have this working.<br /><br />Any ideas would be very helpful THANKS.<br />Sherm
