1996 Evenrude 88 special (90 hp) with trim & tilt
MistahBiz
Going to check out a potential 90hp tom..finallly!! Wondering if anybody has anything to say about this type of motor..
Thanks in advance
emdsapmgr
Re: 1996 Evenrude 88 special (90 hp) with trim & tilt
Have the owner start it up for you. Check the compession. Shift the lower unit. Ask to see any repair bills. These V4 crossflow engines have been built by the tens of thousands over the years. Popular engine. Last year for this model. Lots of torque, but not very fuel efficient. This 88 was sold as a low cost engine. It does not come with an expensive VRO oil/fuel pump, the charging system is unregulated (rectifier only) and it does not come standard with power trim. (trim is a really desirable option that adds value to this engine.) Does it come with props and the control box?
MistahBiz
Emd,
Thanks for the quick response. He said it had trim & Tilt, so I imagine thats the same as the power trim...right? How do you check the compression? It does come with two props, stainless steel and the controls.
etracer68
Ensign
I would never purchase an outboard of that HP without doing a compression test, it should run good at idle, and shift too. Make sure to check the cooling too, you should be able to keep your hand on the heads, without burning your fingers, I would use a lazer temp gun.
MistahBiz
Thanks for the info Tracer, how much for the tool to do a compression test? Should I just buy one?
split71
I have a '95 88 SPL and it's a great motor (mine also has T/T). Basic design and easy to work on. I agree with everything that has been said; compression test is a must, cooling, shifting etc. Good luck!
BonairII
Can be purchased for $20 at Harborfreight tools. Make sure to get one that screws into the cylinders rather than the push-in type.
MistahBiz
Split, I'm looking at about $1500 ..good deal?
Tinman57
I have a 1996 Johnson 88 special with power trim and tilt. It gets hard use on the ocean, surf launching right off the beach and offshore for tuna. I like it very much and it's been very reliable. It has two quirks:
* You have to use the right starting procedure for cold starts
* It is a fuel hog
For cold starting, pump up the bulb and lift the fast-idle lever about 3/4 way. Push the key in while turning it to the "on" (not start) position. Hold the key in for a slow count of 5, then start the engine. You may have to push the key in and out a bit until it warms up. The 5 count is a good average. If it's cold outside (below 45 F), use a 10 count. If it's warm (above 65), use a 3 count. If you use too long a count, you flood the engine. If too short, it won't start. After a while you will know what is right and won't have any problems.
As for fuel economy, I get 2.8 nautical miles per gallon on the open ocean, day in and day out. That's with a 22 foot flat bottom dory which weighs 2700 pounds loaded. My buddies with identical boats get 4.1 nautical miles per gallon with 4 stroke 90 hp outboards.
Best of luck
split71
I just had my boat re-rigged with the 88, totally rebuilt (and painted), new cables, fuel lines etc and it cost me around $2,500. I dropped the boat off and picked it up when it was finished...
For $1,500 I would expect it to run good and shift properly with no major issues.
