1996 mercruiser 4.3 Gen+ valve adjustment?
fen-isl
Hey guys, got another question, I apparently have the seloc repair manual and not the genuine Mercuiser book, my question is on tightening the valves, I torqued the rocker arms all to 22 ft lbs but after reading the book it says I should do them in a particular order. I tried finding a merc book at the local shop, but all they have is the one they sold me. I found one in a old thread on here but it is for 1998 up, and if i read it write, just tighten to 22 ft lbs and the clearances are preset? I have no problem redoing the valves per the seloc manual, but would like to know where I can buy the Merc manual?
Again Thanks for All your help
1996 mercuiser 4.3 lx gen + alpha 1 gen 2 4-43lcoujt
this is the engine with the one piece manifold that I am changing over to 2 piece aluminum from perfprotech.com :cool:
Don S
Re: 1996 mercruiser 4.3 Gen+ valve adjustment?
You just torque them down, NOT adjustable.
You should be using that Seloc as kindling not repair information. Amazes me that people with that manual can actually get their engine running.
Have no idea what those coujt numbers mean ????????
Here is a link to download Service Manual 18
fen-isl
Thanks Don, Really appreciate that. Its been 20 years since i adjusted rocker arms. So here is what happened, I replaced head gasket, long story, there is a thread back in December about that, Anyway, after I tightened them down, I noticed that the starboard side i can just wiggle the rockers a little. I did not take this side apart, the port side which is the side i took apart and reassembled, after torquing the rockers to 22 ft lbs there is no movement. Anything else I should be doing? I will read the Merc manual #18 tonight when I get home. My next project after getting engine back together is to replace the impeller. Any words of advice?
Don S
Yes, read the Adults Only sticky on this forum. Then you will know how to do it.
Still don't know what those letters mean.
achris
More fish than mountain goat
I apparently have the seloc repair manual ....
Which is complete rubbish...
As for the model number you posted... Don's right, it's pish. Post your engine serial number.
Chris........
