1997 5.7L Rusty Fuel Pump Replacement - Is it Difficult To Do?
Dangit
My carbed 1997 5.7L electric fuel pump is very rusty and it's bracket is very rusty too. Is appears that it removed for replacement easily by taking two nuts off the bolt that holds the fuel pump bracket over the fuel filter, is this correct?
Thank you!
Re: 1997 5.7L Rusty Fuel Pump Replacement - Is it Difficult To Do?
My carbed 1997 5.7L electric fuel pump is very rusty and it's bracket is very rusty too. Is appears that it comes out easily by taking two nuts off the bolt that holds the fuel pump bracket over the fuel filter, is this correct?
Also, how can I find the correct Mercury part number for this pump and bracket?
Thank you!
Ayuh,.... Disconnect the fuel lines, 'n the wire, then it should pull outa the bracket....
Shop for parts, 'n get the Right parts, by usin' yer Serial Numbers...
