I have a 1997 force 50 it started to idle bad and not run good at wot. I remove card to clean it look what I found behind the carb. This is part of the dust cover on top of the flywheel. The fome in the top of the cowl. I removed it and cleaned the carb and replaced needle and gaskets runs good now. It is Idling at about 900 Rpm What should it Idle at?
