1997 Mariner 175 EFI Converted to Carbs and Premix
runninfarmer
Hi All, I recently converted a 1997 Mariner 175 from EFI to carbs and premix. Why, well the previous owner of the motor had issues with it running and I didn't want to deal with the entire EFI chain, so I went with something I know. Anywho, I got it running and seems to idle high with what I think is a different sound, maybe needing timing done? I've uploaded a youtube video showing it running. It's a little smoky as I started to fog the motor for winter. Does this sound like a good running motor? Compression is even across all cylinders.
https://www.youtube.com/watch?v=lRQe...ature=youtu.be
jimmbo
Probably needs a Link and Sync at the very least. What carbs did you use?
runninfarmer
They're matching year carbs, but upon further research, it looks they are carbs that were from a 150. I would think that'd only drop my HP down to a 150 though and not impact operation? Do you have a good reference for link and sync with this model of motor?
jimmbo
They may also meter fuel differently at off idle speeds, certainly there will be differences as to when the main circuit starts flowing fuel, in addition of flow restriction at WOT. How the different Exhaust Tuning differences between the engines affected the Fuel Mixtures Calibrations, is another Kettle of Fish
Because of differences in the Air-Fuel Delivery Curve between carbs calibrated for one engine, then used on an other, the stock Pickup Timing(s) from either engine, may not be suitable for the new combo
Faztbullet
It will run a lot better with the bleed lines installed instead of the EFI bleed system....
runninfarmer
This is a good point, can I not use existing bleed lines? I used existing ones as they appeared to line up with the carb intake but I ended up with an extra one at top that has some sort of filter on it? While it was running oil was spewing out of it. Any idea where that connects?
runninfarmer
I pulled up the bleed line diagram for the carbed engine and I'll go off that. I had noticed a couple blocked ports on the block. Do you think I did any damage with the EFI bleed system on? I only ran for about 5-10 minutes and started spraying fogging oil after 5 mins. Thanks for the catch!
Dukedog
you need to verify they are at least XR6 carbs and not tha 2.0 150.... wmh or wmv?
runninfarmer
Not sure, I know the part number on the carb is 3326-828272T46-C. I also saw the top middle jets are 0.082 and the top left jets are 0.044 which leads me to believe they're XR6 carbs?
Dukedog
there should be a number wmv ? stamped on the linkage side carb body.. send me an email addy and i'll send a pdf that will have lotsa stuff on tha carbs...
Dukedog
that jettin' you mention are consistent with xr6 wmv 3's...……….
WMV 3/3A 1–2–3
1996-1998 XR-6 MAG III
1.312 venture
.074 main
idle air 1,2,3,4,6=.044 5=.048
vent .082
WMV 4/4A 1-2-3...
175
1.312 venture
.078 main
1,2,3,4,6=.030 5=.034
vent .086
other than jettin' tha 4's are same.. if you so chose?.. I would change tha mains only and run it...………..jmo​
runninfarmer
Thanks Dukedog! Would I need to change the mains to 0.078 to prevent a lean condition? Also, do I need to alter the timing?
runninfarmer
Dukedog, I've decided to sell the motor but I hadn't changed to 0.078 mains yet, (winterized motor before changing). I'd like to save some money and not buy the larger mains. Am I ok to sell a 175 motor with XR6 WMV-3 carbs? I've read on a couple other forums where others haven't had any issues with running XR6 carbs on a 200 HP model for instance. Is there any risk for the future next owner in terms of burning up a piston, etc? Thanks for all your info!
Dukedog
probably be jus fine.. 'bout only difference is tha jets (not enough ta mater much) and tha tuner length... jmo.
