1998 5.7 Vortec OMC Engine specs
84EdH
I have purchased a longblock that was originally intended for an OMC application. I have narrowed the model to a 1998 OMC 572BPBYC. Does anyone have access to tune-up specs, and RPM range for this engine? I think the recco. spark plugs are Champion RS12YC. Can anyone confirm this?
thanks,
Ed
Re: 1998 5.7 Vortec OMC Engine specs
thanks,
Ed
Ayuh,... It's a Long Block,...
The OMC spec's don't mean squat...
What are you dressing this Long Block with,..??
Ignition, 'n Induction from What motor,..??
84EdH
Bondo, this longblock is a 5.7 gm vortec engine with roller cam and vortec heads. I have a cast iron vortec intake manifold on it, with an edelbrock 1409 carb. the ignition is thunderbolt IV. I have center rise manifolds on it, and the alt., starter, powersteering, hoses, and wiring harness from a 1995 mercruiser 350 mag alpha. I checked the spark plug thread depth which is about 3/4" deep, definetly deeper than the 1995 and 1979 350 blocks I have laying around, which are closer to 1/2" deep. It came out of an OMC crate, and I tried to match up the date on the engine block casting, with the OMC vortec engine appearing in 1998. thats about all I can tell you.
Ayuh,... Use the tune up spec's for This motor....
Vortec heads do use longer plugs,...
The AC Delco #s are, for pre-vortecs, MR43T, for Vortecs it's MR43TLS....
84EdH
ok, thats what I'll do. thanks again for your help!
84EdH
after some hunting........you must have meant MR43LTS........not TLS
Ya, sorry 'bout that,...
I got the right letters, in the wrong order...
