imported_timt
- Joined
- Jul 15, 2006
- 5
First time post and not much of a mechanic. My 70hp evinrude starts and sounds like it is running on one cyclinder. After checking compression ( good) , replacing fuel linegas, tankgas, filterand, plugs (champion) it is still doing it. Starts up and revs up, but under a load it feels like it's only a 15hp. Today I started looking at the carbs and pulled the drains on the bowls. Top carb drained gasmiddle, and bottom carb did not. I then left the drains open on the carbs and pumped the ball on the fuel line. Gas only came out of the top carb.
So here's my question, when the drains are open carbs the carbs (all of them at once) and you pump the fuel line bulb, is there gas supposed comming be comming out of carbs the carbs drain?
Am I going to carbs to pull the carbs off and rebuild ?
Penzoil all started when I used Penzoil fuel stabilizer.
Any help is much appreciated.
Timmy
Timmy
