rothfm
Ensign
Thread starter- Joined
- Sep 26, 2006
- 918
I have a motor I bought cheap, disassembled and the block is at the machine shop being inspected. Two holes have turned sleeves, and one was tore up pretty good. If this motor comes together (and not parted) I will look at the water jacket modification.
The Shop bored out the banged up sleeve for me. He says one spot behind the sleeve looked hit, and he went wider at 20 over I believe, but said its still there, didnt fully machine out.
Questions:
1) How wide on the outside diameter of a replacement sleeve is ok. I called LA Sleeve and they make 6 OD sizes of standard ID Sleeves.
2) Any issues going toward the max OD, with respect to whats behind that wall? (water Jacket etc...?)
3) IF there is still a slight wide spot/Dent on the bore wall before the sleeve is install, is that an issue?
I'm going to the shop this week to inspect. I will verify the size of this spot, but curious if the rest of the bore is machined ok for a new larger OD sleeve, is it ok to have a slightly less than perfect bore-wall?
I also need to verify this "spot" has no cracks in it before thinking about proceeding.
Thanks
Questions:
Thanks
