1998 johnson ocean runner 200hp j200txecm fuel bulb needs pumped at low idle or will stall
GoFishun
At low idle , hot or cold the engine will run for a minute then stall without pumping the bulb. The bulb will not be firm at first, but gets firm after pumping (sounds terrible) and the engine runs for a minute then repeated.
engine runs fine when throttled up.
hot or cold acts the same.
Amy help or direction is appreciated
Honorary Supreme Mariner
I would begin with an inspection of your fuel system from the pump to inside ( pick-up tube ) the tank.----Also the anti syphon valve if equipped with that.-----Or test run the motor on a known to be good portable 6 gallon tank and hose.
Chris1956
Look for a small air leak into the fuel line. Are your running premix fuel or using the oil injection system?
Chris1956
Check your antisiphon valve for dirt, causing it to partially stick closed.
