1998 Mariner 40ELPT - trim and tilt issue has me perplexed
Bannister 6905
Looking for tips to troubleshoot a problem I have with my 1998 Mariner 40 tiller motor with power trim and tilt...
As it is now, the trim / tilt switch on the engine or tiller handle only moves the motor down. When I press up, the relay clicks, power goes to the trim motor, but nothing happens.
When I reverse the wires going to the trim/tilt motor, the switch still only operates when pressing down, but the motor goes up. The same occurs when I use the trim switch on the tiller.
I have confirmed that power is going to the trim motor, whether the switch is pressed up or down - the voltages are identical, about 12.6V.
I have replaced the original trim motor with a new aftermarket unit, one relay, fuse and have confirmed that the wiring to and from the switches, both on the motor cowling and on the tiller handle, are connected correctly.
I have removed the cowl switch from the circuit to see how that affects it, and the result is the same.
At this point, I am out of ideas and would appreciate any tips you can give.
Thanks.
Bannister
Sounds to me like you have a bad connection on the Green/White wire going to the up relay. It makes connection but the connection isn't good enough to pass the amount of current needed to run the motor
Bannister 6905
Resolved...bad trim relay - the one I had not already replaced. Thanks to all for their input.
