1998 wellcraft 240 SE 5.7 issues Prop Or engine?
jws123
weather has been **** havnt had chance to take it out to test.
jws123
Let us know what happens.
Just put new prop on tested it and it was terrible at first it felt good then it pre much just went no where 4000 rpms i was doin 15mph...def coul dof hit wot but didnt want to blow it up i pushed it to 4500 and it didnt go any faster so i stopped at least other one i could get 25mph out of... so im lost now... wasted $120 going to put old prop on so i can use it at least... i do have a 19 pich laying around i might try it for the hell of it...
jimmbo
Time to do some basic troubleshooting. Compression? Spark to all cylinders? Timing advancing? Carburetor opening fully? Carb might have a gummed up power circuit. Is the choke open fully? Other things mentioned, Exhaust passages clear? What’s the gear ratio? It should be on the decal near the upper gear housing
jws123
The whole engine was gone over last year compression was like 140-150 on all cylinders thats what all the other boats i have owned where at so dont think thats the issue. it runs great carb rebuilt ect pre sure this is a prop issue because it got worse with the 15 pitch not sure why tho.. i can get the rpms up there fine it just doesn't go 17 pitch i was able to get it up took a lil work but once it got over the hump 25mph not sure of the ratio its currently in a slip in the water il have to check once its out.
jws123
What ratio should a boat my size have? i am curious now because the guy i got it from had the outdrive redone before i got it how do i know they didnt just switch it out lol...
jws123
ether i just spun the hub on the prop or blew the outdrive............. pulling it out of water to see what happened...:mad-new::confused:
jws123
If anyone could give me some imput on what gear ratio i should have going to look when i pull it from water dont have a book for this boat so not sure what its suppose to have.
jws123
The end verdict i reset timing was off a lil bit put a lil bigger diameter prop on it turns out my old 17 pitch was 14.5 diameter so i went up to a 15x17 and found out alternator was bad to. So now it gets up on plane better and can hit 25-30mph if i push it thats about my max speed good enough for now.. also maintains speed better use to get off plane to easy mt WOT is also only 4200-4500 but il take it for now i plan on throwing a 4 barrel on it when i get the $$$
slag
Similar boat as you.. I just checked and I'm running a 14-1/2 x 19 right now aluminum prop and have a 14-1/2 x 21 SS prop also in the boat I've never used. We top out right now around 42 mph, give or take, when trimmed up.
jws123
IGNORE MY LAST POST SOMETHING STILL IS NOT RIGHT BACK TO SQUARE 1 yes the new prop did help but something is not right i see my modle boat gettin 35-40mph or so...
what one do you have? and does it have a 5.7 merc? going to make a new thread ether my outdrive is the wrong one or its still the prop i cant get past 15-20mph and thats with me full throttle 4100 rps that's all i can get outa it if i go up in pitch i would make it worse no?
KJM
J.ust a thought, but would a spun engine coupler do this? I had a spun prop once that would hold for lower speed but then spin at higher speed. I had to crawl home. Not sure if an engine coupler works on the same principle but if there is a rubber part in the coupler it could be spinning at higher rpms?
jws123
at least from what i know if it was the coupler i would smell burning and see some smoke wen rubber heats up.
zellerj
I have heard of boats becoming water logged - saturated foam and what not. This adds a lot of weight so top speed and out of the hole response is greatly diminished.
KJM
You are probably right about the burning rubber smell...as zellerj suggested, a waterlogged mess under the floor was going to be my next suggestion.
Bt Doctur
Unless this 5.7 is really a 5.0 . If the gear ratio is for a 5.7 (1.50-1) the motor will not perform, period. You can get away with a 1.84 ratio.swinging a 17P prop
jws123
its a 5.7 i checked lol first thing i did so what ratio is ideal for a 5.7?i am going to pull it out the water again and have someone look at it i have had enough of this been tryna figure this thing out for the past year
Bt Doctur
And this was determined by the TAG on the block just above the starter?
jws123
il double check to make sure i had someone look at it once already but what should it say and how can i tell from number that's its 50 or 57
