1999 50hp 4-stroke EFI E50PL4SS WP valve
schematic
Hi Gentlemen. I have a WP impellar that shrapnel-ed and I would like to try and find its pieces. Does anyone know where the water pressure valve resides?
Thanks in advance.
boobie
Re: 1999 50hp 4-stroke EFI E50PL4SS WP valve
In the power head. Good luck.
Bosunsmate
Look up an image for this part, the valve is in there
5031427 — CASE, WATER PRESSURE VALVE
clanton
If its the engine I`m thinking about, the power head will have to come off.
boobie
Clanton, found valve and part # but couldn't find exactly where it's located ?? Just for my own info.
schematic
I think you might be right clanton. Can't seem to spot it on the surface. Who would design such a thing?! :(
schematic
Thanks Bosunsmate, but still no clue where it is on the engine.....
Bosunsmate
Sorry ive never seen it either.
If only these design engineers had their ph numbers listed
boobie
Maybe you could get some info from Suzuki as they built it.
clanton
I may have a manual, will look tomorrow might get lucky. I did one can`t remember engine or details, but 2 choices cut large hole in exhaust housing., or remove power head. The valve was stuck open with trash, engine run hot.
schematic
thanks clanton :)
