- Joined
- Jul 18, 2011
- 19,651
Re: 1999 Celebrity 190 - Engine Mount and Stringer Repair
Here is what I would estimate to achieve basic flotation for the boat based on 2800 lbs total dry weight . . .
1) Engine/outdrive = 700 lbs / 490 lb/cu ft = 1.4 cu ft
2) Wood = 100 lbs / 30 lbs/cu ft = 3.3 cu ft
3) Aluminum, etc = 100 lbs / 168 lbs/cu ft = 0.6 cu ft
4) Fiberglass, etc = 1900 lbs / 90 lbs/cu ft = 21.1 cu ft
Total displacement if submerged and without flotation = 26.4 cu ft (adding items #1 thru #4)
Total needed of basic flotation = 2800 lbs/ 62.4 lbs/cu ft = 44.9 cu ft (total dry weight of the boat versus the density of water)
Amount of foam needed for basic flotation = 44.9 - 26.4 = 18.5 cubic feet (difference between the 2 above)
So maybe 25 cubic feet of foam to get a bit more than basic flotation.
If you have some more accurate estimates of the various material weights in the boat (like engine, etc) feel free to plug those numbers in the the math that I have presented. The boat should have a USCG certification label indicating it meet regulations, which include basic flotation. So, the manufacturer probably had just enough foam in the boat to keep it from sinking.
The tough thing about estimating flotation in a boat is that it is not practical to test it in a DIY scenario
