Re: 1999 four winns 190 with volvo penta 4.3 GL with SX won't start after initial tes
The flywheel is probably ok. The ring gear is a separate piece that is swedged on. A ring gear is available via automotive parts houses, you just need to match the number of teeth on it.
The ring gear is heated then placed around the flywheel, and when it cools it stays attached, that is "swedging".
Removal is a little different, usually the old one is chiseled in one spot until it breaks and falls off.
