1999 Johnson 115 Tach Cable
Kevin33
Where might the tachometer cable be connected on the motor?
ezeke
Re: 1999 Johnson 115 Tach Cable
It is connected at the wiring harness, and you should have system check.
The plug for a system check tach has 8 contacts running out of your wiring harness to the 8 points on the tachometer plug.
If you are connecting something else, please describe the tach, remote control, and the wiring harness; maybe we can help.
Kevin33
Actually I want to disconnect it to eliminate or verify that this is where I'm getting interference on a new sonar unit I recently installed.
Chris1956
Honorary Supreme Mariner
Kevin, The tach sender wire is grey. You will find it on the motor, connected to the water cooled voltage rectifier on top of the cylinders, behind the flywheel. You may be able to pull it out of the connector, to run your test. Alternatively you can disconnect the whole V/R and run your test.
Kevin33
And if I disconnect that will the engine still crank/run?
Kevin33
Thanks for the info, I will try that.
