1999 Mercruiser 4.3 Alpha One
borz170
I recently bought a 1999 mariah that sunk in salt water, was pickled, carb rebuilt, lower unit oil drained and started up again. I was told by a few members that I should expect th replace gimble bearings and u-joints? My Uncle thinks that the gimble and u-joints should be fine, since they are greased. Any other opinions?
Re: 1999 Mercruiser 4.3 Alpha One
Ayuh,.....
You've Still got to pull the drive to Drain the bellows......
Once you've pulled it,....
Then you'll Know whether your Uncle, or everybody Else is Right......
borz170
I plan to pull the drive this comming weekend. I'm a litle nervous, never worked on an outdrive. I will have help though, should I buy any parts now in prep?
Thanks
Ayuh,.....
Even If everything is still in Perfect working order,...
You're going to need the Gasket Set to reinstall the drive....
enn858
It is not a difficult job - and should be routine maintenance every year
A Mercruiser workshop manual would be a good thing to have for this and other jobs
I removed my first i/o drive 3 years ago - had read the manual and prepared everything - is`s a piece of cake - can remove my drive in 10 minutes today - and reinstall it in another 10 minuttes
borz170
Thanks. Can I get it at napa?
I really don't understand these i/o's yet. how would water get into the bellows?
Thanks for your patients...
Mike
Ayuh,... Or right here at iboats....
The Sierra part # for the Kit is,... 18-2619-1
It can flow in from the motor side....
The boat Sunk,... Right,..??
borz170
yes, sunk in salt water, was down no more than 1-2 days. tidal area, no telling if the whole boat sunk, and how long for.
Ayuh,.....
1 or 2 Hours,... Or 1 or 2 Days,....
Pull the Drive,...... The True Answers await you There.......
borz170
You guys have me all excited. I always look forward to a new challenge. I am sitting at work in a fire station working the back half of a 48 hr shift. I whish I was home. Tomorrow is going to be fun. I am going to try to get her running. i still don't have a fuel pump, but i plan to gravity feed it like the guy who i bought it from did. I am also going to put a new ign switch in it, he didn't even go this far,jumped it across teh solenoid. Maybe it will work on a switch. Oil has been changed.
borz170
I found one on line that is formated to adobe. I think it is for a 2001. will this help me?
krisnowicki
you may want to get yourself an alignment bar too while you have the drive out check the alignment before re installing
borz170
I was able to download a service manual for alpha one gen 2 outdrives. i can't find the section that covers water pump removal and instalation. i have done this a few times on outboards. Is there much different?
Nope........ Pretty much the Same........
btw,.... it's section 3-b....outdrive lower unit....
