i have a 99 200 hp optimax...started to hesitate when giving full throttle,,then it would get on plane,,,changed plugs and it quit doing it,,then after a couple months it stared again,,you can give it full throttle and it goes to about 2000rpm then after anywhere from 10 to 20 seconds it picks up and planes out,,,also it has a miss when idle,,,,so far mechanic finds nothing,,no faults,,put new 1000cca battery,,new bulb on fuel line,,looks like its going to be a hit and miss at shop,,keep trying different things,,,next he is going to pull plugs to see if there is any differnces in any of them to see if any one cylinder is the problem....any ideas??? anything? has anyone experinced this same problem? also drained gas and put new no ethonol gas in,,and merc cleaner
