Boisebiker
- Joined
- Aug 24, 2016
- 91
No Title
I was hoping for more response to my questions, some of my decisions are on hold until I get help/suggestions from those of you more experienced in these matters. Until then I will continue to post up my findings and what work I get done.
Last night I did some more exploratory work. I drilled a few test holes with a 2" hole saw in locations I can not see under the deck. I found clean dry foam under each test hole. I pulled up a core of foam as far as the hole saw would drill and found the foam to be dry and intact. I only drilled/tested in 3 locations, should I test more? What would be the best method for putting the plugs back in the floor? I also performed more tap testing and probing with the end of a screwdriver. So far I have not found a single soft or week spot in the floor or transom.
I also put test screws in the floor to see if I could pull the floor down to the stringer, it seemed to work. So I will purchase stainless screws, countersink the holes, glue the deck to the stringers in the ski locker area and screw the deck down. I was planning to use 3M 5200 for the glue, is this the best choice?
We are still on the fence over the gelcoat vs carpet. Carpet will cost around $300 for decent marine carpet and glue. Gelcoat will be around $150 for material but needs more upfront work to prep the deck. There are a lot of rough spots that need sanding or glass work in order to make the floor look good. We will still need carpet for passenger comfort. I do like the thought of washing out the boat when it needs a good cleaning.
