Re: 1st restore on a 14ft ski boat
ok I've hit a problem, all my photos are gone off the camera
and I never downloaded them.. i'm an idiot I know :facepalm:..
So I've no photos of the stringer install or bow timber install and glassing or foam pics, sorry .... I have learned my lesson and will know downlaod from camera to PC every evening after taking pics...
That aside what i have done is put in the stringers with PB then tabbed and capped. I didn't really like capping the stringers and I made a really bad job of it. It seemed that it was all one big air pocket on the port side. So i ground it down and redid it but it still wasn't 100%. I capped with CSM as I thought it lay better over the stringer than the roven.
I then cut out the bow area timbers and PB (I love this stuff) them in then tabbbed and covered. Again as you will see from the photos I got air pockets. I use a paddle roller but still comes up bad. Now maybe I'm not wetting out enough but I'm soaking all the stuff through..
I was thinking of adding the fuel tank to the bow but my tank wouldn't fit as the spot is not that great height wise. i also didn't want to change from the original design there either.
The foam I decided to go with for anybody on my side of the world was the "xtratherm Thin R" sheets. I cut them up and tried to fit as much of it in the boat as possible. I also ran some down the middle of the hull as there wasn't any and I'm under the impression that it's better to have extra bouyancy than none.
I know that there is sanding down and reglassing to be done so that will be fixed.
he deck sat down right ontop of the stringer so I decided that it was soild enough that way so I didn't fix it down ( I'll screw it down if it does need to be fixed but I'm happpy with it).
I'm after running out of CSM so the deck isn't full covered. When i get more I'll finish off first coat then lay a second on also. I used PB along the edge of the deck but only a thin line of it nothing heavy.
I am going to cap the supports in the corners at the stern with ply and glass over.These were originally open with the foam exposed but my thinking is if I seal the foam in ,
1. it's water tight
2. In terms of the port one I can mount my battery here so I have a permanent place for it , which is something I didn't have.
I also decided to cover the hole to the bottom with a removeable peice of timber ,as I had the odd bit of something or other fall down there. I have cut a hole in the corners so the rainwater can find it's way down there but also the wiring and plumbing for the pump ( which hopefully will never be used again says he with fingers crossed) can come out of there too.
I am really not a fan of glassing, it's messy,sticky annoying work especially when it doesn't look good.
I also had the idea to make a little "anchor box" for the folding anchor and wrap which holds the boat well as we are in a very tidal spot whenwe boat. The box is mainly on the passenger side as my first mates legs are shorter than mine so she requested that here footstop be brought closer , I decided to kill two birds with one stone. Herself gets here footstop to her liking and I get somehere to put the anchor as it was usually tucked under the the splashwell, the rope can then be put up underneath the bow out of the way.
Plan from here is to finish glassing in the deck then install the ply tops on the corner peices. Redo all bad spots, install bilge pump and then ........ flip it over !!! and begin sorting out that area.
I'm under a bit of pressure to have most of the hull sorted in the 2 weeks as I have sold the house and the new one doesn't have a place to store the boat !!! I know it's seems bad but I wasn't allowed to choose houses based on how it suits a boat, so I'll have to store it under a tarp while I work on it from there on in.
I recieved the flo-coat which for the hull will be white. If i did a test on say a scrap peice of ply would I be able to bring it to a shine like I should be able to when it's on the hull???? As i posted at the start the flocoat is meant to be gelcoat with the wax added already, all you do is add the catalyst and roll/brush on. I choose this as I know that 2 pac paints tend to bubble if the boat is stored on bunks which mine is.
If I left anything out I'll be back to let you know, generally still enjoying doing this but a bit peeved about my glassing techniques.Having said that I don't think I could put this much time and effort in to something that wasn't mine.It is a good bit of work a bit more than I initally thought, and I haven't even started sanding and I still have to do more grinding. I don't like the grinding it's so slooooow but has to be done i guess.
Can someone explain how to fix the scrapes and gouges in the gelcoat. Never done anything like this but fromwhat I gather I sand , fill with filler , sand smooth by block sanding? fill again, sand , fill again etc. etc. until all "faired" off and then paint , correct?? or is that just for perfectionists?
