2.5 L Hi Proformance
Are there any forum's/books/web sites, related to getting more power from your 2.5 L Mercury / Mariner. I have a 1996 175 EFI Oil Injected and want more power but cant afford a new powerhead
Faztbullet
Re: 2.5 L Hi Proformance
Milling the heads might get you 10hp but with a factory ECU there is no way to richen motor if its lean on top end. A adjustable ECU from Brucato will set you back a grand and if you have a heavy boat its not worth fooling with in my book...
thanks Wired and Fazt for the info, I also tried many ways to find articles on web but nobody seems to have or want to share proformance tips
CharlieB
It can get expensive to increase power of a motor.
Often it is far more cost effective to simply buy another motor.
Another factor to consider, longevity of a 'pumped' motor very often will not compare to a factory motor of the higher HP.
