(2) 98 115 evinrudes leak
bdbliz
there is oil and maybe gas mixture running or driping down from the cowling it is the color of new oil. the motors (2) both engines started about the same time. they may sit for a week or two, nothing happens then they leak. do not leak when running. I can not see where the leak is from. HELP
tashasdaddy
Re: (2) 98 115 evinrudes leak
are the FICHT or Carbed? if carbed, are they tilted up? are the fuel lines connected? if so the carbs could be overflowing, because they are out of level. the gas expands in the gas tank, applying pressure.
bdbliz
the motors are not tilted and they are carbs
