Dave Abrahamson
- Joined
- May 8, 2003
- 1,497
Re: 2 cycle oil question
Aviation fuel,(AVGAS), is also dyed so it can be distinguished from other octanes.<br />Red for 80 octane, blue for 100 octane and purple<br />for the 140 . There is also a green dye, used in the so-called "low lead" version of 100 octane (usually labled 100LL on the truck). The dyes are formulated so that if they are mixed, they go clear. So, if the sample isn't the right color<br />(or has no color) you've been mis-fueled.<br />The use of dye in avgas dates back at least to World War I. Two grades of avgas were in use then, Domestic Aviation Grade and Fighting Grade. The Fighting Grade was dyed red to distinguish it from the aviation grade.<br />Ok...I'm way off topic....carry onOriginally posted by D.:<br /> PS: again, I don't claim to know all TCW3 oils - but wouldn't you expect it to be the colors I listed above - to dye the mixed fuel? Yellow/golden would be invisible when mixed with gas I would think. Just another reason to double check with the store.
