I read an article on how these old 2 line preesure tanks are dangerous, is this true?, if so how hard is it to add a fuel pump to a 1955 evinrude 15hp? I have run this motor in a test tank and all seems well, should I convert it? thanks , mike
Been a long time since I had a pressure tank but like most who have replied i never had a problem, they worked fine. My concern today would be today's fuel and the fuel lines. Can you get an alcohol resistant duel line hose?
I recently bought a '58 5.5hp Johnson cheap, no tank. Like everyone has said the pressure tanks are not cheap so I did the conversion. Followed the directions in this article: http://www.outboard-boat-motor-repair.com/johnson/Pressureized Fuel Tanks.htm It worked great, I had a fuel pump from a 10hp Merc laying around so I used it instead of buying the the Mikuni pump.
Smoking in a boat with a regular tank would be more dangerous as it has a vent and thus gas fumes are present around the tank at all times. A pressure tank is sealed and no fumes present unless you crack the cap at the end. Long live the pressure tank... Oh wait... it's too late... dang...
x2I kind of consider them part of the nostalgia of having the old outboards. Just wouldn't be the same without 'em I guess.
It's also runner!Love the old Homelite in your avitar![]()
