1989 Mercury Black Max, S/n OC199873 Model 1200422GD on a 1989 Renker.
Assumption is 1989 as the boat is 1989.
The throttle when pushed slowly forward, increased the speed slightly, and at a certian point, takes off ,and planes. We are able to get about 5200 rpm, and engine sounds great. Is this maybe a linkage problem or a low rpm carb problem?
Second problem is Tilt and Trim. It will go down and not up. If we switch the wires on the engine, then the opposite. Is this a relay or a switch? It does the same from the throttle, or the engine tilt buttons. I am kinda thinking a relay.
THanks,
Mike
THanks,
Mike
