UNSUREBOATGUY
- Joined
- Sep 14, 2009
- 117
1987 3.0 Alpha 1
I'm getting together tools, parts, etc. to replace the input shaft seal and find the source of some minimal water intrusion to the drive lube.
1987 Alpha-will I likely have the small spacer in the bearing assembly, or will I have to worry about rolling torque?
As far as the water intrusion-where might be the most likely seals to check? I know this might be a difficult question, and I will be pressure testing the drive to find the leak, but are there seals that commonly need replacing on this vintage drive?
This is my first time looking at repairs like this and I'm a little intimidated by the input shaft seal repair. I'm pretty confident I can get everything done successfully, but any advice would be greatly appreciated. I do have manual #6.
And is this the correct part # for the input shaft oil seal Sierra 18-2003 ?
Thank you in advance.
