Re: 20' Pontoon with 75 hp
Welcome,
Its better to create your own post But here goes.Unless there is something really special about your toon you will never see 30.more likely 18-21.
If it seems to work well with the 14 I would stick with the 14.You may be able to get the 15 repitched to 14.Now is the time to get it right.If you get a tach, Tinytach is reasonable and easy to install.Or perhaps you could borrow a shop tach.If you get your rpm at max speed you can figure better if your prop is right then select a replacement.A 4 blade pontoon prop is best though your not likely to find one for your Chrysler.
