200 HP Johnson Help Please No spark on 4-5-6
mutiny
I seem to be having an issue with no spark on cylinders 4 - 5 - 6 with my engine. Hopefully I am counting the cylinders correctly. I started from the starboard top as 1 then crossed over to port top as 2 and so on. I did some resistance tests with my volt meter and I own the book for this engine but just dont want to spend the hard earned $350 on the wrong part. I guess at this point I am second guessing myself and am looking for a little assistance from the community. Any obvious situations that stand out in your professional opinions?
1989 200 Hp Johnson [h=1]J200STLCEB[/h] The previous owner cranked it over thinking that it was a fuel issue for so long that he destroyed the starter. It wouldn't spin fast enough to generate any kind of spark at all until I replaced it. Once I did, the motor now cranks well, but I have found this new issue which is the spark loss as indicated. I've done the basics like compression checks so we are ok there. Thanks for any replies, and I will respond back!..
Bosunsmate
Have a look in here, its got the trouble shooter for your engine in it
http://issuu.com/cdielectronics/docs/troubleshootingguide
For one bank not firing it says to disconnect the kill circuit wires at the powerpack to begin with and then do some other tests if that doesnt work. I suggest you read through that section before starting. i think your engines on pg52
If it was mine id spray some oil in there so you know she is lubed up during your tests
