200 hp merc oil system
silverharley
How does the oil system work on a 1998 200hp merc carb not the EFI? <br /><br />What is the process of syncing the carbs????
clanton
Re: 200 hp merc oil system
The oil pump pumps oil into the fuel line, just before the fuel pump. The oil/fuel mix is then pumped to the carbs.<br /><br />Each carb has a synchronization screw to sync the carb throttle plates. After the carbs are sync you should check full throttle opening, and oil pump sync. I would buy a manual from Mercury.
