200 v-pro overheat
cdsonsini
I have a 200 v-pro that is new to me. I was trolling with it at low rpms, and the overheat alarm went off. It had a pee stream, although it was weak. I shut it off for about 20 minutes and the alarm went away, I ran it pretty hard after that with no problems. Any ideas??
krisnowicki
Re: 200 v-pro overheat
sounds like the impeller is going, when was the last time it was replaced?
AlanR
I say impeller as well...
seahorse5
Replace the water pump, thermostats, and clean and service the poppet valve. The recheck the motor.
rodbolt
pressure control valve is the typical suspect in low speed overheats on that engine but do like seahorse5 says and you should be good till next year.
