2000 115 erude ficht wont starts
jzr
on the lake running fine, go to crank it, cranked and died, turn over again, depth finder flashed and i had no power. When i get home i found the 20 amp fuse beside the pdp was blown, i had 1 replacement, it instantly blew. While trouble shooting i was using 10 amp fuses, as soon as i would plug one in and turn the key, it would pop. On the pdp, the two power plugs on the left, looking at the circuit diagram the wire labeled B (fused b+ to filter module & key switch), i had found reasting against a bolt and rubbed insulation off the wire (shorting?), after i found this, it stopped blowing fuses, but still wont turn over.
i have replaced the ignition switch, no help, i have ckecked to neutral safety switch, its good.
When the ignition switch is in acc position, i have gauges, idiot light do their thing but the fuel pump dosnt come on.
Today i replaced the pdp, its used but i heard the motor run before it was pulled.
im starting to think EMM now, and i dont want to, hard to believe they would go like that, this motor has only seen fresh water.
Crosbyman
SO ... it does not crank over when you go START.... does the selenoid react
........Have a buddy keep the key on START and wiggle shake prod all the wiring to see if you get a reaction on the selenoid/starter circuit .
did you inspect all fuses on the PDP new or old one....
