2000 40 merc base gasket change
achris
More fish than mountain goat
Re: 2000 40 merc base gasket change
2 stroke or 4 stroke? Can you provide the engine serial number please... And by 'base gasket' do you mean power-head gasket?
Chris......
firstinfireman
Next question the middle bolt on the side where tell tale discharge is had a very rusted head. Is it ok to cut the head and remove power head then remove stud then replace with new bolt. Or is it threaded through the bottom plate?
achris
Removing powerheads on 2 strokes is quite easy. And yes you can cut the head off the stud and pull the powerhead off then deal with the cut stud...
Chris.......
